Okay so an update on the SL55, I bought it relatively cheap as it had the PSE dreaded issue!
Excellent! Do keep an eye on it though, I have had PSE's on R230's that have been "repaired" but cause battery drains etc. So whilst it may work, it may keep the canbus alive. Just keep it in mind if you are trying to track down a battery drain in the future.
On 30 posts but still cant send a message to 00slk! haha
Water had leaked in the boot, through the rear windscreen seal and I have just managed to remove the seal and I can tell it has never been replaced in its life! All x4 nuts were corroded, had to be very careful with them so I could save the rubber and reuse it, managed to get it done.
So yeh back to the car and PSE issue, the chap who had it sold it to me due to a PSE fault and wasn't happy to pay around £1k to sort it.
I removed it all and took it apart, bearing in mind that I had a new one on the way. So if anything went wrong then I have plan B.
Obvious liquid damage to the pump. Took it so a friend of mine who then took me and the pump to another friend who is basically a geek! Told me to get myself to Maplin, buy a can of PCB spray cleaner and a fibreglass pencil to clean up the damaged area which was around 10cm long.
Cleaned it all and left it for a couple of days, basically cleaned up everything in the PSE pump and reconnected the battery today and to my disbelief I have a working PSE pump!!!
Everything on the car works and it's like it never had a fault! So now what do I do with the new PSE pump which I spent best part of £500 on!?
Really chuffed today, roof also works although I have on order the revised gear cover as on of the flaps (elephant ears) is sagging a little.
As you can probably tell I did my research on these R230's before buying one! So far so good (touch wood), I now have a fully working SL55 AMG! Well expect for a few other minor bits ;-)
