Run flat tyres: daft question
Lord_Lucan
Bedfordshire, UK
No longer own a Mercedes Benz
Hi All,
How do I tell if my car has them fitted? I've tried looking at the tyres on my car (Bridgestone RE05As) for some distinguishing marks such as RFT, RSC, SSC etc but I cannot see any.
The info/display under service indicates that run flat sensors are active or running or whatever the term is. So does that just mean the circuit has been activated by the previous owner but that the car doesn't actually have them fitted?
Told you it was a daft question :)
I would say they are not , when I had run flats it was written on the sidewall . But I will add a ?? Just In Case :D
turbopete
Spennymoor
I think it will be tyre pressure monitors NOT runflat as in the tyres are run flat. they are to warn you of a soft tyre (possibly through the ABS sensors or through actual tyre pressures, theres 2 methods to do it)
John Laidlaw
Wirral
Land Rover Discovery 4
I had those Bridgestones on my Audi and they were not run flats
Lord_Lucan
Lord_Lucan
Bedfordshire, UK
This is where I'm even more confused as you apparently can get run flat versions of that tyre according to black circles anyway
Frontstep
T210 320cdi
Run Flat tyres?
You will be able to check whether your current tyres are Run Flat tyres by checking the sidewall.
Unfortunately there is no industry standard code to represent this and different manufacturers use different symbols or letters. These are as follows:
Continental – SSR
Dunlop – DSST or ROF
Goodyear – ROF or EMT
Bridgestone - ROF or RFT or RSC
Michelin – ZP
Hankook – tyres will be marked with HRS or have B at the end of the product number (e.g. K115B)
Pirelli – RSC
Yokohama – ZPS
Lord_Lucan
Lord_Lucan
Bedfordshire, UK
That's precisely the same passage of text I used to check the sidewalls but I didn't see any of the Bridgestone RF markings
rf065
Grossbritannien
I have run flats on one of mine, it does'nt have "run flat sensors" either running or active, it has a tyre pressure monitoring system like many other MB's without run flats.
Russ
Lord_Lucan
Lord_Lucan
Bedfordshire, UK
Ah so it could well be me being a 'tard then. Ok will check again tomorrow. Thanks
SunnyDee
West London
C250 W204 Petrol Coupé
Sorry just saw this
"RIP Television (Malcolm)
Gone but never forgotten"
Has Malcolm passed away? :(
John Laidlaw
Wirral
He sure did Sunny Dee much to our sorrow
There are 2 threads currently in the Benz bin, have a look and you’ll get the history
John Laidlaw
Wirral
I thought the were suffixed ROF though?
Anyway IMO if there are no suffixes that would mean they’re not run flats?
Lord_Lucan
Lord_Lucan
Bedfordshire, UK
Just been out in the car and the option states "Run flat indicator active" under the service menu.
I still think it would have to say or have a code somewhere , so the tyre repair monkey would know what action to take in the event of a puncture .
Lord_Lucan
Lord_Lucan
Bedfordshire, UK
I think you're right guys. I will take another close look when the rain stops just to be sure but I'm guessing the code should be fairly prominent.
Either way it's not a big deal. Just had a replacement key made by Mark of RMK and their service is just as good as previously experienced. First time I took the car on a decent run today and it's such a comfortable motorway cruiser with lots of power on hand if needed :)
Get a couple of pics up buddy , not seen any yet ! Mileage , service history ?? :D
Lord_Lucan
Lord_Lucan
Bedfordshire, UK
  • #17
Full MB history, covered 82k, artico interior, heated front seats, DAB, Bi-Xenons.
Can't upload pics from my phone according to the error message as they're too large. Will try from the laptop later.
Same mileage as mine now . Maybe time to get another ATF change and maybe a diff oil as well if she is going to be a keeper :D
Lord_Lucan
Lord_Lucan
Bedfordshire, UK
  • #19
I'm using the mobile browser so can't see your signature: what trim etc is yours?
Yes I was thinking the same re: ATF too. From what I've read it's not a diy job on the 722.9 as it was on the 722.6 but no great shakes. I'll check the book again to see if it's had a diff oil change or not but more than likely it hasn't.
Avantgarde , leather on my E320cdi . Yep it's not really a DIY job , but it could be done if you shell out for one of the vertical fluid pump thingys , but by the time you have bourght that you may as well pay an Indy the £200 .
There is no service schedule for diff oil replacement , but that is a cheap and relatively easy DIY job , I think I've done both my cars diffs twice now (but I've got issues :D )
Keep on eye on the orange turbo inlet seal for drips on the om642 . If you search "salmon tin" on this forum , you will see some pics of a thing I made to stop drips/let you know when the seal drips.
The om642 really likes clean air filters as well , which is an easy enough job when you combine it with the turbo inlet seal change .
