SL55 AMG (2003) Electronics
lovemerc
South Wales
ML250 GLE AMG Sport. Previously - SL500 R230 2003 & S430L W220 1999.
After cleaning what i could of green corrosion on the plugs, I have today carried out the voltage test after Malcolm's updated DIY.
I removed the b,bk wire from the CAN. With the door open and radio on, (to make the system active), whilst one CAN was good at 4.65v, I still got a high reading of 0.65v on the CAN that should be 0.025v. (It was 0.5v when the car should be sleeping too) I then replaced the b,bk wire, removed each plug and tested each time. Still got the high reading.
I also took out each plug and tested the voltage on each individual wire and this also showed the same high voltage on each of them!
Any idea what's going on ?
That is all correct and perfect, the main thing is they should go back to the 11 volts and 0.025volt when all turned off,, if they do its all perfect.
lovemerc
South Wales
Yes I get that Malcolm thanks, but as I say, CAN H is not ever going to 0.025v, it's never below 0.5v or neither are any of the plugs individually.
If CAN H never gets back to 0.025 then there is one thing still awake or running, the key should be out of the car when testing and its a matter of unplugging to see what is live and the first place to start is the X30/15.
Something is leaking there.
lovemerc
South Wales
Yes, I get that too, but as I say, each of the plugs are live and showing this reading of 0.5v when unplugged regardless of any connection to the CAN. surely they can't all be leaking or am I not understanding what you mean?
Find the plug that comes from the EIS switch, this is the master and see what is on that lead
lovemerc
South Wales
Sorry Malcolm, I should have said, this wire behaves the same and is also 0.5v, plugged in or not :confused:
How can this common voltage be on all plugs if they are not linked?
The only way to measure them is really on the rear of the can connectors with most plugged in, I have never checked the actual plugs, but we could have a no load situation where the voltage is high when the circuit is not loaded, 0.5 volt is quite high, it only goes to 0.65 when active. do a check on the X30/18
lovemerc
South Wales
Ok, will check that one too but why would separate circuits on the CAN all have the same 0.025v reading?
As another thought, shall I remove the front fuses one by one and check the readings to see if it isolates or is that not going to help me with the circuitry that leads to the CAN?
That is the running voltage on CAN H 0.025 dormant and 0.65 active, is there any change in this voltage when dormant or active.
It might help by taking out each body fuse
lovemerc
South Wales
I'll take out the fuses and test then.
The dormant reading is 0.5v and active goes up a bit to 0.65, that's the issue I've been raising on all my recent posts like the one above.....
That can sure account for your drain on the battery,,, just a matter of finding it.
Gkinghorn
Bournemouth
E350 CDI Cabriolet - 2011
Just doing my usual trawl through all the usual R230 issues on the forum and I noticed this post from Malcolm has the diagrams missing. Given the usefulness of this thread to the R230 community I wondered of anyone else had the images to link this to?
This is the heater box and 430 is the drain for this box
The fan motor is 160 but not much to be gained from there as far as i can see
The air intake parts in front of the screen are all here
010 A 2308300013 A 2308300013 COVER COVER
AIR/WATER DUCT AIR / WATER DUCT
010 010 A 2308300513 A 2308300513 COVER COVER
020 020 A 2308320190 A 2308320190 DRAINAGE PIPE DRAINAGE PIPE
WATER DRAIN,LEFT WATER DRAIN, LEFT
030 030 A 2308320290 A 2308320290 DRAINAGE PIPE DRAINAGE PIPE
TROUGH ON THE RIGHT TROUGH ON THE RIGHT
040 040 A 2308320099 A 2308320099 SEALING RING SEALING RING
BETWEEN COVER AND DRAINAGE PIPE BETWEEN COVER AND DRAINAGE PIPE
320 320 A 2308300053 A 2308300053 AIR INTAKE CASE AIR INTAKE CASE
ENGINE COMPARTMENT,FRONT ENGINE COMPARTMENT, FRONT
320 320 A 2308300453 A 2308300453 AIR INTAKE CASE AIR INTAKE CASE
330 330 A 2308350351 A 2308350351 CONNECTOR CONNECTOR
330 330 A 2308350451 A 2308350451 CONNECTOR CONNECTOR
340 340 A 2308350118 A 2308350118 GRILLE GRILLE
MOUNTING TO INTAKE BOX MOUNTING TO INTAKE BOX
340 340 A 2308350218 A 2308350218 GRILLE GRILLE
350 350 A 2308350139 A 2308350139 COVER COVER
360 360 A 2308350014 A 2308350014 HOLDER HOLDER
CONNECTOR CONNECTOR
365 365 A 1408320084 A 1408320084 DRAIN VALVE DRAIN VALVE
Richardstrivens
New Registration
Mercedes SL500 R230 2004
I have this problem on my SL500 had the water under the passenger seat and cleaned the drain out which was blocked then I also pulled the carpet up to dry out. My problem now is that I have no sound on the CD player and was wondering if this water under there also causes no power to the AMP and other equipment in the rear of the car. I have been through the finer optics and I can get the red light to the amp but if I bypass that I can't get the red light at the next so I assume there is no power to the three things in the back being AMP, telephone and something else. Would the wet under the passenger seat cause this?
