Soft close
Hi all
New CL has an issue with the softclose.
On the drivers door, it pulls it in, but keeps pulling for approx 10 seconds where It then stops pulling the door and puts the windows back.
At the end of this the door is fully closed but it's not right.
I assume there are two switches in the door latch, one that detects the presence of the door and one that detects its fully closed.
It does not seem that I can check these on star. Any ideas?
  • Moderator
  • #2
OK follow up. Drivers door issue is a leak. Somewhere. Required pressure is not being built.
Same with bootlid.
Passenger door is an issue with the microswitch. That one will be fun...
Easiest way to find a leak? Smoke test?
  • Moderator
Well, I can't hear any leaks in the cabin when it's pulling the door, so it must be in the boot near the pump or possibly the hinge.
m2287
Cambridge
Bentley Continental GT - S55K AMG - RR vogue - Mazda6 estate
I had a leak on the boot hinge of one of my w220s before, I didn’t replace the whole pipe, I cut it and sleeved over it.
  • Moderator
Many thanks, I will have a play with my vape and a bit of hose to see if I can find the leak. Its not an audible one at least.
m2287
Cambridge
Sounds similar to mine, it was just pot luck that I found it right away! Maybe try some things on the air circuit with the boot lid open to see if you can hear anything in the boot.
  • Moderator
Ill get my wife to lock me in the boot :)
As the car has been repainted, its more likely somebody has left out some tiny o rings etc.
Could always try pulling the fuse then stick it back in Alex unless you’re completely sure there’s an air leak
  • Moderator
So I had a play today. Not quite sure what is happening. I have codes for both front doors and the trunk lid exceeding closing time.
With the boot open, I can actuate the soft close mechanism via the latch and it pulls in. I can hear the pump running, it runs for 10+ seconds then times out. I cannot hear any leaks. I will need to test the lines the with a vac tester to see if the door actuators have a tiny leak.
All soft close functions work, but the pump runs much longer than it should.
All central locking/multi contour etc all works fine.
m2287
Cambridge
No water in the pump?
m2287
Cambridge
Do the lumbar supports work in both front seats?
  • Moderator
Yes, all other PSE functions are 100%
Soft close works as well, just the pump runs for much longer after the door/boot lid has been "sucked in".
Ill pull a vac on the lines and see if they hold.
  • Moderator
Boot lid and passenger door elements are vac tight.
Pump runs for 10 seconds when closing the boot which is a bit odd considering no leak.
Drivers door has a very small leak somewhere, highly suspect it's in the actuator knowing my luck.
m2287
Cambridge
How about in the door hinge where the cables normally crack?
  • Moderator
Haven't checked where the leak would be in the drivers door circuit yet, but Im pretty sure the reason the PSE pump runs constantly is that the pressure switch has an internal leak:
This does not move when the pump runs so that explains why the pump runs until timeout on all functions (apart from central locking)
bembo449
gainsborough , lincolnshire
having some fun there Alex , I take it you were aware of this problem when you bought the car ??
Flyinspanner
Ruislip
I was thinking system pressure sensor, and then see you’ve found a stuck pressure switch. Wonder if it can be freed with some lube, or has it failed electrically?
  • Moderator
  • #20
No but it was a private sale.
Thing is, it all still works fine, it's just the pump runs on for a while each time you use it. The pse master says that the pump is probably worn and that the pressure switch is a red herring.
