Swap of Comand NTG3 Panasonic (Japan) to Europe NTG3 (Becker)
F
Frode Storkaas
W221 S65 AMG 2006 + W210 E55 T AMG + W169 A180 CDI
  • #21
I have installed the europe Version.
Had to buy both the comand and the amplifyer. A lot of rewiring had to be done. Works fine, but Bluetooth/phone is no longer available. Did also ad DAB and AUX.
Total cost about € 3000
Best regards
Frode
Botus
S500/2010/500
Best regards
Frode
NTG3 doesn't support Bluetooth telephony
the BT feature you may have had in the menus is I believe an optional extra and its not for phone to car BT telephony....
it was only for BT dumb handset to connect to the phone plugged in the armrest.... the wireless handset in the rear arm rest connects to the UHI socket in the front, via BT, I have the device in my car
856 PHONE HANDSET IN REAR ARMREST
Ender
W221 s500
hello, I have a w221 japan version. I have worried the comand ntg3 europe version. can I send the pin assignment / wiring diagram / connector occupancy please. Thank you. Greetings from Germany
Botus
S500/2010/500
wow 6 extra multiplugs and 2 extra fakra connectors.... no wonder its not exactly plug and play
Ender
W221 s500
Hat jemand die pin belegung?
Csaba Kristály
Registered
S600L/2006/5500V12
Hello, @Frode Storkaas
The car was fitted With an European command unit, and amplifyer yesterday.
They did a lot of wiring, and removed the video player, radar warner +++.
Hope they are able to set the car up With the Star program. Will know on monday.
Best regards
Frode
can you send me the wiring diagram for w221?.
thanks
i like to replace the comand from japan ntg3 to eu ntg3.
Willi Werle
w211
Can somewhere send me too the wiring diagrams
thanks
i will replace the comand too
Chrishazle
Nr Ashford, Kent
Hope all the new posters on here realise there's a 30 post limit before you can use PM's (now called Conversations, same thing, you can't start or receive one), so those of you with only a few messages cannot send or receive PM's!
Roland R1
New Registration
S350
Hello, i need help please, i have a S 350 Year 2006 Japan Version, equipped with a Command NTG 3 without HK/ Logic7 .
The car is in Paraguay, South America, the Radio frequencys are the same like in ECE and USA.
How i can programm the ECE / USA frequencys into the NTG3 ?
Is the a aftermarket solution for this issue?
Thanks a lot.
Botus
S500/2010/500
you can't just programme it
yes there is an android system, no idea on quality.... and you still have lots of fun moving from Japan loom to the android unit. But its been done
re "the simple conversion from Japan to Europe set up"... check the photos in the post above
5 extra multi plugs and 2 more fakra connectors joining up goodness know what they fit in a japan spec car
whilst the post above saying they did it is good news, I'm sure is was a lot more than 40 hours of research and at least another 25 hrs of doing the mods once they understood which wires to join...
this is a job for an expert with both sets of wiring diagrams, lots of spare wires and a great terminal tool alongside connectors I have not been able to find in the RS catalogue, plus a copy of the main dealer programming tools AND lots of experience and lots and lots of patience
android on to a std car
https://mbworld.org/forums/s-class-w221/710915-w221-android-touchscreen-15.html#post7963768
Andrei G
Registered
W209/2003/320
I have received the Japanese wiring diagram.
best regards
Hi, can you please share the japanees diagram,I have the same issue,I m working the pinout on a japanees comand in order to fit it in a EU car.
Best Regards !
Alfie
Surrey/Cotswolds
www.comand.co.uk
.................................................Total cost about € 3000
Best regards
Frode
And there you have your answer!
Its simply not worth importing a Japanese model in the hope of saving a few quid. Unless you are particularly attached to the car!
mioba
Nottingham and Köln
its not worth it at all. I very briefly looked at getting a japanese R class a few years ago.
Once I researched and seen what was involved with amps, tuners, frequencies, wiring, antennas. I binned the idea.
if I was in your shoes get a Kenwood, pioneer, android system and even then hope for the best.
www.W140.co.uk&www.r129.co
