Tightening small hose clips... Help
silestanix
London!
03' BMW 325Ci
Morning all, so I've got some new vacuum hose from MB and new hose clips, how the hell do I tighten these?! Cheers...! Pics attached...
umblecumbuz
Wales and Gozo
Hose Clip.jpg This should help. It shows what you need to do, and the tool to do it with then becomes obvious - as mentioned above.
I have done it in the past by using a pair of mole grips and two small bolts, each bolt lying along the face of the returns on the part that needs squeezing. This way, you're squeezing the bolts themselves which in turn deforms the clip as required. Fiddly, but possible.
silestanix
silestanix
London!
03' BMW 325Ci
Cheers gents!
Managed to find an old pair of side snips which I almost threw away but ended up keeping, worked like a charm! Thank you very much for your help, have a good Saturday afternoon!
davemercedes
Glos
Don't think I've seen them... a bit OTT aren't they?
- If they tried really hard they could make the job harder!
L John
W204 C350 Petrol Elegance
I use them in my job too, I believe they're called lemon clips.
silestanix
silestanix
London!
03' BMW 325Ci
They're standard fit on the vacuum pipe I just replaced... Opening the old ones destroyed them unfortunately...
davemercedes
Glos
Hmm I'd better look around under the bonnet, then.
- Are they supposed to be better than clips with a screw and groove or bolt-through ?
- Or maybe just designed for a production line?
L John
Cheaper for the production line in terms of cost per unit and fitting time but they also have a smoother inner section for clamping the hose more evenly. I've never had one leak but have had to adjust a fair few jubilee type clips to get a good seal especially on thinner walled hoses.
L John
Lemon clips have "ears" on opposite sides, hence the shape/name :)
Ah, that makes sense.
The clips with the single clamp points always come in parts kits for my job so I've never needed to order them separately. When I was shown how to fit them I was told they were called lemon clips but couldn't see why.
ajlsl600
france
https://www.google.com/search?q=plastic+ratchet+type+hose+clips&tbm=isch&source=iu&pf=m&ictx=1&fir=UH7ch4RXOYcwKM%3A%2C0_ZBKkgnsA5r9M%2C_&usg=__Gsrk77iPfuogQL22OQ7ESPvNMAU=&sa=X&ved=0ahUKEwiRo83h2pXXAhVIExoKHRNkAPgQ9QEILDAD#imgrc=UH7ch4RXOYcwKM:
less likely to cut into pipe. only real dissadvantage is on small pipes if not careful removing one can brake the fitting itself .that can be expensive .especially in restricted access areas, ie most modern large engined cars...there are some quite strong platic ratchet type clips about now that are re usable
John Laidlaw
Wirral
Land Rover Discovery 4
They’re the Oetiker type, very popular on construction lines. Officially they are a one use clip as unlike the worm drive mechanisms of ‘Jubilee’ clips they wont loosen or vibrate loose. On the other hand they’re not adjustable of course!
They are on my E class fuel filter pipes , that's when I first came across them . I sourced a cheap pair of pliers from eBay to get them on again .
rifiki
Worksop
CLK W209 W121190B
I have used tie raps on vacuum hoses.
ernieh
Scotland, East
Be aware that some tie-wraps do not like UV and/or heat and can degrade surprisingly quickly. To be sure, I usually buy mine from an electrical wholesaler as theirs may be used outside.....and they are also less than half the price of those from a well known diy store!
Ernie
