Conor
- Jan 22, 2019
- Location
- London, UK
- 2010 S212 350 CGI // 2004 R230 500
Morning all,
Some of you might have seen my ABC Suspension overhaul thread, here. While working on the ABC I noticed bits of rust here and there, and decided I would remove (along with the front) the rear bumper and side skirts as well as all body panel and perform a thorough inspection.
While I would really like to crack on with the ABC work, I think it will be a lot easier to do this job without any pipes and struts up front where there is a lot of patchy corrosion.
I wasn't horrified, and a lot of people would dismiss the rust as just being surface. While it only surface rust, structural rust issues don't appear out of thin air and i've yet to see rust get better on its own, so here we are.
The biggest areas of concern are the rear boot and a few areas where the seam sealer is starting to fail.
I seem to have accumulated quite a few body shop products since working on my Clio 172 Cup track car. My aim is to use up what I have hoarded on this job as opposed to buying new products.
The primary objective of this job is to tidy up the underside and "reset" any corrosion. It won't be a concours job by any means but I will use the OEM Jasper Blue to keep things reasonable looking underneath.
Here comes a bit of a photo dump with some commentary as I go.
I hope you enjoy this - I know I love these types of threads anyway.
