Conor
- Jan 22, 2019
- Location
- London, UK
- 2010 S212 350 CGI // 2004 R230 500
Hello all
Has anybody had a go at this?
The car is nearly 19 years old now.. and with a leak around the front valve block. Technically you can still drive it if you keep the system topped up... but I am taking that as, as fair a shot across the bow as you can get on this car/system.
You might recall the pics from the last time I had to troubleshoot some pressure related errors. -- I know the general consensus was that the pump might have gotten low on fluid. I know that's bad for the pump but I don't think it's shot.. and if it is i'll replace it.
Anyway.. this whole area started off dirty, I cleaned it.. now it's back to same dirty state again.
I have a fantastic place to work out of at the moment indefinitely so I'm thinking about getting this up on stands for some resto work before next spring/summer.
My ideal underside restoration would be:
- Drop both subframes (Is engine support from top feasible on these?)
- Clean up and treat rust then seal underside. Something like wire wheel/Bilt Hamber products, paint then BH wax or something.
- Tidy up subframes and re-paint with suitable coating.
- Replace brake lines with Cunifer
- Replace ABC plumbing (lines / fittings) and rebuild the valve bodys. I suppose it would be worth replacing the three spheres also.
It feels to me like a BIG list and a LOT of work.. but the most substantial piece of work by far would be the ABC work which is the highest priority. Once the car has been stripped to do that work, it feels like the other stuff wouldn't be massive as everything should be easily accessible.
Question: They say the "car killer ABC pipe" that runs under the engine, requires engine removed to change. Where exactly does it run? If you supported engine from top and removed the subframe would you be able to change it?
Also, if I do this - what kind of stuff am I likely to need to purchase? For starters I am thinking:
- All the hoses / pipes, to / from valve blocks, pump, shocks, spheres etc..
- 3x Spheres / dampeners. Rear / Front and return
- Valve block repair kit x2
I plan on removing all the hoses/pipes and having copies made up by a hydraulic hose specialist. I won't be going near MB for them as I genuinely don't see the need. I see a lot of people re-using the fittings this way. I would clean mine down on a wire wheel, treat and paint.. as I am sure these are MB custom and hard to replicate?
It would be great to hear from anybody who has really gotten down to nuts and bolts on the underside of this car.
I think it's worth it.. this is a fantastic car which I really enjoy driving in the summer months. The way I see it is that the car is approaching 20 years old now.. and this work done would give it a very good chance of being reliable for another 20 odd years or so.
