Underside tidy up - R230 edition
Conor
London, UK
Morning all,
Some of you might have seen my ABC Suspension overhaul thread, here. While working on the ABC I noticed bits of rust here and there, and decided I would remove (along with the front) the rear bumper and side skirts as well as all body panel and perform a thorough inspection.
While I would really like to crack on with the ABC work, I think it will be a lot easier to do this job without any pipes and struts up front where there is a lot of patchy corrosion.
I wasn't horrified, and a lot of people would dismiss the rust as just being surface. While it only surface rust, structural rust issues don't appear out of thin air and i've yet to see rust get better on its own, so here we are.
The biggest areas of concern are the rear boot and a few areas where the seam sealer is starting to fail.
I seem to have accumulated quite a few body shop products since working on my Clio 172 Cup track car. My aim is to use up what I have hoarded on this job as opposed to buying new products.
The primary objective of this job is to tidy up the underside and "reset" any corrosion. It won't be a concours job by any means but I will use the OEM Jasper Blue to keep things reasonable looking underneath.
Here comes a bit of a photo dump with some commentary as I go.
I hope you enjoy this - I know I love these types of threads anyway.
20231114_125801.jpg 20231114_130043.jpg 20231114_130739.jpg 20231114_130744.jpg 20231114_131012.jpg 20231114_131145.jpg
Jesus Connor , you really don’t do things by halves do you ! Impressive stuff .
Conor
Conor
London, UK
Here you can see the rear of one of the ABC level sensors. Quite rusty. For better or worse, i'm not a "leave well enough alone" kinda guy, so I removed both of these. I snapped 2 of the 4 studs holding them on. And one of the nuts was rounded off and I really couldn't manage it off given the tight space and obstacles.
Between this and the ABC work, the overarching goal is to make the car "reliable" (As much as an R230 can be) .. I don't want to do all this and then have the level sensor mount rust and snap while i'm hundreds of miles away and cause a red ABC error...
My only real option was to sacrifice the mount for sensor by wiggling/snapping it off. When this was off, I was able to get a vise grip over the rusted nut and get it of. Bliss..
I then set about cleaning the car .. did I say I hoarded a few products!? I also had to put down some plastic sheeting to catch the mess. The floor is bare concrete and I hat the way it stains. I must run it by landlord that I will paint the rectangle under the lift to alleviate any big staining.
Some post cleaning shots. It's enough for me to work without getting dirt, but when I run a white cloth around it, it still turns out black. I guess that's ok, for the kind of job I want to do. Once I have the rust cleaned up etc I will give another clean with degreaser before touching up, so it should be fine.
At least now it's nice and clean, and I can see what needs to be done.
Rusty bolt for washer bottle there. While I don't plan on going over the bend. I might replace a few of these, or at least put them in the ultrasonic with vinegar and paint before re-adding. I know nobody will ever see them.. but it's nice to be nice to this car..
Conor
Conor
London, UK
Here is one of the places the seam sealer has failed..
Not sure why this point is rusty... i'm guessing it's the lowest point of chassis rail where all the water runs to.. :/
Conor
Conor
London, UK
.. Then I moved onto the rear end.
The boot area is probably the most advanced corrosion, there is one small section that seems to be advancing. If this was left another hand full of years you'd seeing some light steel that would need re-enforcement. A stitch in time and all that..
Here is a quick clip of the rust. I needed to remove the exhaust to remove the heatshields in order to make a full assessment and also get at 95% of the rust. There is still a bit that will be tough to get at, but I will do best efforts and spray with wax after anyway.
Then you have the rear areas around the jacking points (both sides) - various bits of corrosion etc. To do a decent job on this, that strut will need removing. I will also need to prop up that corner with something and temporarily remove that vehicle lift arm.
I think the only tool for the job is this, which I don't have. I do have a hydraulic transmission jack, but can't rely on hydraulics. I'll probably borrow one because i'm not working at the moment.... and for the first time in my life i'm (trying to) exercising financial restraint..
It's worth pointing out at this point that I have been examining the brake lines. They aren't bad, but I will tidy up any light corrosion and cover with wax.
I did notice one of the fuel lines was a bit more advanced, rust wise than the brakes. I need to tread carefully there. I might treat and wax also. What's the deal with replacing these? I've not seen that done before.
Another failed seam at the rear jacking point, offside.
Here is the near side rear where all the ABC plumbing is .. a bit rough, eh!?
I've decided that this time around I am not replacing the rear plumbing, as it's honestly not too bad (that I have seen). I do need to rebuild the valve block though. So I will probably dismantle this area a little bit and get at that rust.
Nearside rear jack point.
Fuel line vs two ABC lines.
Fuel line again I believe. I'd be happy to take opinions and advice on what you would do with this fuel line. Needless to say that rust bracket will come off and get the same treatment as all other ABC pipe mounts.
Sheet worked well.. I basically picked up all the corners and directed the liquid into the middle where I placed a load of cat litter and saw dust. That cat litter has soaked up countless oil spills and now all this. Definitely time to renew it.
Transmission sump looking a bit sorry up there.. I have some black hammerite i'll use to touch it up after the rust is cleaned up.
Conor
Conor
London, UK
A few other pics I took towards the end of day..
I'll see what I can do with these heatshields. Most of the mounting points are corroded. I would like to buy new and they aren't that expensive.. but I really don't want to be spending money at the moment, if it can be avoided. I am conflicted.. because this car deserves to be treated well.. I do have some over size one way type washer fitting things .. they should suffice for now.
Exhaust came out a lot easier than the E class.. and no, the boat isn't mine. It might transpire that I was practising some level of financial constraint afterall.. I think boats are another level.
Propshaft bearing is fine .. that said. While I am this far in, I will be replacing the two couplers (guibo) as it will be easier, they are a bit perished and the car has a lot of torque. Big patch of grease there is the handbrake mechanism which looks in good order.
Is there ever a case to be made to clean off all the old lubricant and apply fresh stuff, or is that fine? I'm inclined to think the latter, but as a novice, just checking :)
And yes, the engine has a bit of a leak .. I'm inclined to think it's rocker covers as they are common on the M113, I believe. That will be done before this sees the road.
This ugly duckling looks ripe for a clean up.
Conor
Conor
London, UK
While i'm in there, I might replace these nuts too.
It's hard to draw the line.. The reality is that I have a lift now.. and a lot of these little tasks can be postponed until later. I mean to replace and tidy up these nick nacks is a mornings work another time.
That said. I will be using this car for a while when I overhaul my E class so I don't want things getting worse.
One final thing that I forgot. A number of those rubber plugs have failed and I will renew them, after spraying the cavities with Bilt Hamber Dynax cavity wax.
Believe it or not folks... you have made it to the end of my initial photo dump.. I hope you enjoyed it.
I will probably post another update after the weekend.
Conor
Conor
London, UK
I don't ... sometimes I wish I did lol..
Thank you - Hope you are keeping well :)
Conor
Conor
London, UK
I really wish I had the wherewithal to video document this and start up on YouTube.
But between faffing around with cameras and lighting... not to mention editing. I think the overhead would be too much.
It's really annoying in this workshop. The sodium lights make for a green tinge in my photos.
s5tuart
2003 R230 SL350
Good luck Conor.
I can get all my engineering fix just following your threads.
Mark Q
Warrington
R 230 SL 500 2004 & Nissan Navara, Jag F-Pace, BMW Z4
Wow, once more you have really gone to town. You've also given me more things to concern me about the R230, I'll be lying in bed now wondering how much rust is growing in the never seen places. Fantastic job, you should work for Car SOS or similar.
Also I'm in awe of what else is in the garage, really impressive. :D
Conor
Conor
London, UK
Thanks Mark.. some very kind words there.. but maybe let's wait to see if the job gets finished LMAO..
Conor
Conor
London, UK
I wanted to call out a particular issue I had in removing the rear bumper.. and incidentally, how storing a car outside over a single damp winter can wreak havoc.
In June 2020 I did some work on the rear arches. At that time, I was easily able to remove the 4 bolts (2 x each side) that screw into speed nuts. All good.
Fast forward to August 2023 (after a cold damp winter outside in Ireland, or two actually)... those same bolts are now spinning in the speed nuts and I have a bit of a headache on my hands.
Note: At 16 years the fasteners opened just fine.. then 3 years on they are rusted and spinning!!
The bolt in question, is the rusted looking one in the centre of the picture, which is just on the inside of the rear quarter. It was spinning on the speednut on the other side, which was totally inaccessible.
I have the unenviable task of trying to figure this out. Luckily I had just the tool.. My Black and Decker power file/finger sander. Armed with a fresh belt, I went to work.
As you can see, minor damage to the quarter.. where you need to be very careful, really. And I wish I didn't mark it at all. In any case, I will just give it a quick lick of paint and it will be fine.
Also note the towel, which was used to prevent metal filings from entering unwanted areas.
At this stage you can see we have remove the bolt head and you can see the round profile of the round screw part of the bolt - perfect. I proceeded to give a few light taps with hammer and punch to issue some persuasion for the next step.
From the outside, I then used a trim removal tool, plastic, to avoid marring my lovely Jasper Blue paint job.. The trim tool acted as a lever to pry the bumper away from the quarter and we were in business.
Funnily enough it was only the foremost bolts (1 each side) that had this problem.. the rears came out just fine.
Needless to say i'll be using some copper grease when it all goes back together.
It was a decent solution for me, but I wonder what alternatives people might use had they not got a power file on hand.
I’d use my dremel and cut off discs for that
00slk
Cambridgeshire UK
Conor, I had the same issue with one formost bolt on the right. What I did (as I was painting the 1/4 anyway) was slide a plastic trim remover in, forcing the bumper down and undoing the bolt at the same time. The more weight applied forcing the bumper down the tighter the caged nut fought. It put up a good fight, but with the weight applied the bolt started to unwind and the caged nut nut finally gave up the fight and relented. No paint work was harmed in anyway :D
I replaced the speed clip.
I always copper slip any bolts, suspension, bumper and any small outer trim screws. It works a treat.
Conor
Conor
London, UK
  • #20
Evening all.. did a few more bits on Wednesday mainly on the rear end.
While I gather enough steam to make that upload, please see the repair of my friends blasting pot (that I broke) in preparation for blasting a few bits on the car which I want cleaned but hard to get at with my usual bits.
