VIN decoder?
AMGeed
Poole, Dorset
S204 C180K
Thankyou
Couple of interesting ones in that list
Firstly 7 speed transmission
It defo hasnt got that !
Pedestrian protection ? Hmmmm
This is the datacard from a different decode site. Looks the same as the other one?
A 722.9 is a 7G auto box.
Parameter Value
Ident. number (FIN) WDD2210222A119214
VIN WDD2210222A119214
Baumuster 221022
Sales name S 320 CDI
Order number 0 6 537 13781 (Destination: Great Britain)
Delivery date 09 01 2007
PAINT1 775U BRIGHT SILVER METALLIC CLEAR COAT PAINT
Interior color 201A LEATHER - BLACK/ANTHRACITE
Engine 642930 40 339389
Gearbox 722902 01 048781
General data for model code 221022
221022 S-class W221 S320CDI
642.930
722.902
SA codes
Parameter Value
182 CONVERTER WITH DEV. CHARACTERISTIC
200A LEATHER
205B OWNERS MANUAL AND SERVICE RECORD - ENGLISH
221B SIGN COOLANT/REFUELING - ENGLISH
23N STEUERCODE WERK SINDELFINGEN/GRAZ
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
250B MOBILO LIFE/EUROPE SERVICE PACKAGE
25N STEUERCODE WERK SINDELFINGEN/GRAZ
283B AIRBAGLABLE - ENGLISH
427 AUTOMATIC TRANSMISSION 7-SPEED
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
474 DIESEL PARTICULATE FILTER
477 TIRE PRESSURE LOSS WARNER
527 COMAND DVD APS WITH NAVIGATION
537L GREAT BRITAIN AND NORTHERN IRELAND
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
581 AUTOMATIC CLIMATE CONTROL
5XXL EUROPE
600 HEADLAMPS - CLEANING EQUIPMENT
613 HEADLAMP LEFT-HAND TRAFFIC
666 PRODUCT PROT.F.TRANSPORT VEH. W/O TIE-DOWN HOOKS
669 SPARE WHEEL / FOLDING WHEEL
807 YEAR OF MODIFICATION
875 HEATED SCREEN WASH SYSTEM
882 INTERIOR SAFEGUARD
885 HIGHTEN THEFT PROTECTION
910 DYNAMO WITH HIGHER CAPACITY (FFO)
983 COC PAPER EURO 4 TECHNOLOGY W/O REG. CERT. PART II
989 IDENTIFICATION LABEL UNDER WINDSHIELD
A21 SHIFT BY WIRE
A22 NEW CONVERTER GENERATION
A24 JOINT FLANGE, 4-ARM 120
A34 TORSIONAL DAMPER VARIANT
A45 O-SHIFT PLATE WITH VGS2
H08 WOOD TRIMM CALYPTUS
K11 ADAPTIVE STOP LIGHT FLASHING
K12 STEUERCODE FUER SERVICEINTERVALL 30000 KM
K13 CONTROL CODE FOR SERVICE INTERVAL 25000 KM
M30 DISPLACEMENT 3.0 LITER
M642 V6 DIESEL ENGINE OM642
Q21 GV - VA-BREMSSCHLAUCH MIT SCHLAUCHAUSSENHAUT EPDM
Q31 GV BEFESTIGUNGSDUEBEL
R01 SUMMER TIRES
R44 LIGHT ALLOY WHEEL 7-SPOKE DESIGN 17" ALL-ROUND
U60 PEDESTRIAN PROTECTION - ACTIVE ENGINE HOOD
U72 DVD PLAYER WITH REGIONAL CODE 2, EUROPE, JAPAN
V23 SPEED- + LOADINDEX 99W
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
And the EPC version (which these are taken from) is the same. How many gears do you think it has?
Datacard
Identification number: WDD2210222A119214 3
Chassis
Sales designation: S 320 CDI
Order number: 0 6 537 13781
Delivery date: 09 01 2007
Paint code 1: 775U BRIGHT SILVER METALLIC CLEAR COAT PAINT
Equipment: 201A LEATHER - BLACK/ANTHRACITE
Engine no.: 642930 40 339389
Transmission: 722902 01 048781
Engine
Major assembly variant: A 642 010 75 02
Part var. design.: 64293040
Text FUER DIESES FAHRZEUG KANN ALTERNATIV DER RUMPFMOTOR A642010804680 GELIEFERT
WERDEN
FOR THIS VEHICLE THE BASIC ENGINE A642010804680 CAN BE SUPPLIED ALTERNATIVELY
SA code
200A LEATHER
5XXL EUROPE
A21 SHIFT BY WIRE
R01 SUMMER TIRES
bembo449
gainsborough , lincolnshire
Well when im in D and cruising at say 60 , i get a 4 next to the D , when in manual mode i can get any higher than 4th either , very odd , it is noticably less smooth than the 7G box in my 216
bembo449
Hmmm , well it drives lovely , its smooth and quiet , mpg seems about right so what could be going on ? With it being a derv , does it alter what gear it will let you select at a given speed or load ?? With me being used to the V8 im not sure what to expect from a derv version ??
keefysher
Hampshire
W166 GLE350AMG Line 3.0 2017. BMW Z3 2.8 1998.
When was the ATF last changed? You may need a software flash too. At 60mph what revs is the engine doing? Would expect it to be in 7th tbh on a flat road.
bembo449
Right , ive had a play today , in manual it will only let me go higher in gears as the speed builds , i didnt make a specific note of the speed required but i will tommorow , i may do a fluid change as a matter of course and see what my local indy will reflash the box for , other than these the only bug bare is the lack of factory xenons which on a car of this class came as a surprise
bob 6600
On a 2007 S Class that's shocking and taking the pee!
siR
Edinburgh
C63 & Golf GTI
WDD1760522J479206,
Could someone decode this please.
WDD1760522J479206,
MB Vin Decoder
CHASSIS
VIN: WDD1760522J479206
FIN: WDD1760522J479206 7
Manufacturer: Mercedes-Benz
Model: AMG A 45 4MATIC
Order number: 0 6 536 01569
Delivery date: 20 04 2016
Equipment: 651A FABRIC/IMIT. LEATHER/MICROFIBRE - BLACK/ANTHRACITE
Paint code: 787U MOUNTAIN GRAY - METALLICH FINISH
Engine #: 133980 80 067821
Variant: A 133 010 80 00
Transmission #: 724016 00 966718
SA CODES
05B OPERATORS MANUAL AND SERVICE BOOKLET ENGLISH
06U MBCONNECT - BASIC SERVICES
098 STEUERCODE F. APPS API-SUPPORT
117 PAPER CONTROL ROWI CERTIFICATION
140 MEASURE PACKAGE 1
218 REAR-VIEW CAMERA
235 ACTIVE PARK ASSIST
241 ELECTRICALLY ADJUSTABLE LEFT DRIVER SEAT W MEMORY
255B MB MOBILO WITH DSB AND GGD
258 COLLIS.WARN. SYS. W/ ACTIVE BRAKE INTERV. FCW STOP
275 MEMORY PACKAGE (DRIVER SEAT. STRG. COL.. MIRROR)
281 AMG PERFORMANCE STEERING WHEEL
290 WINDOWBAG
294 KNEE AIRBAG
30P COMPARTMENT PACKAGE
335B INSTRUMENT CLUSTER/HU LANGUAGE - ENGLISH
345 RAIN SENSOR
350 MBCONNECT - ECALL EUROPE EMERG. CALL SYS. GEN. 2
357 SD CARD NAVIGATION
37A FRONT AXLE LOCK
3U1 EUROPE/CIS COUNTRIES/MONGOLIA HEAD UNIT
413 PANORAMIC SLIDING SUNROOF/GLASS SUNROOF
429 7-SPEED AUTOMATIC DUAL CLUTCH TRANSMISSION
440 TEMPOMAT (CRUISE CONTROL)
459 STEEL SUSPENSION WITH VARIABLE DAMPING
471 MECHANICAL LOCKING DIFFERENTIAL
475 TIRE PRESSURE MONITOR (TPM) HIGH LINE/MID LINE
4U7 VOLTAGE DIP FUSE FOR START/STOP SYSTEM
500 OUTSIDE REAR VIEW MIRROR LH AND RH FOLDING
51U BLACK FABRIC ROOF INTERIOR TRIM
522 AUDIO 20 RADIO NAVIGATION CAPABLE NTG5
537 DIGITAL RADIO STANDARD DAB (DIGI. AUDIO BROADC.)
538 ATTENTION ASSIST (DROWSINESS DETECTION)
543 SUN VISOR WITH ADDITIONAL FUNCTION
555 AMG PERFORMANCE SEAT
5XXL EUROPE
608 AUTOMATIC HIGH BEAM SWITCH (IHC)
631 LEFT-HAND TRAFFIC STATIC LED HEADLAMP
638 AMG DOUBLE-SPOKE WHEELS 19" ALL-ROUND
650A FABRIC/IMITATION LEATHER/MICROFIBER
6P5 STEUERCODE VERTRIEB FUER CODE 475 ANFORDERUNG
772 AMG STYLING PACKAGE-FRONT SPOILER. SIDE SKIRT
776 WHEEL ARCH ENLARGEMENT
806 AEJ 25/1
810 PREMIUM SOUND SYSTEM
818 CD SINGLE DRIVE
857 COLOR DISPLAY 8" DIAGONAL
873 SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS
877 AMBIENCE ILLUMINATION
889 KEYLESS - GO
927 EURO 6 TECHNOLOGY EXHAUST GAS CLEANING
968 COC PAPER EURO6 TECH. W/O REGISTRATION CERT.PART 2
A17 DAS 4
B03 DIRECT START / ECO START/STOP FUNCTION
B08 ELECTRONIC HORN
B09 REFRIGERANT COMPRESSOR WITH MAGNETIC COUPLING
B51 TIREFIT
B54 MBCONNECT - REAL-TIME TRAFFIC DATA
B59 TRANSMISSION MODE SELECTOR LEVER (AGILITY SELECT)
D5B No code designation available
DP0 No code designation available
F176 MODEL SERIES 176
FS COMBI - VEHICLE
G016 TRANSMISSION CODE VERSION 16
GA AUTOMATIC TRANSMISSION
HA REAR AXLE
J31 CONTROL CODE RASTATT/MERCOSUL PLANT
JWO PLANT CONTROL CODE
K14 CONTROL CODE FOR SERVICE INTERVAL 20000 KM
K27 SOFTWARE CONTROL FOR FORCE-FREE IN POSITION "D"
M005 VEHICLES WITH 4-MATIC-/ALL WHEEL DRIVE
M133 R4-OTTOMOTOR M133 - AMG
M20 DISPLACEMENT 2.0 LITER
P49 MIRRORS PACKAGE
P54 THEFT PROTECTION PACKAGE
P71 AMG DYNAMIC PLUS PACKAGE
R RIGHT-HAND STEERING
R01 SUMMER TIRES
U01 REAR BELT STATUS INDICATION
U10 FRONT PASSENGER SEAT WITH WEIGHT SENSING
U21 SPORT EXHAUST SYSTEM
U25 ILLUMINATED DOOR SILL
U26 FLOOR MATS - AMG
U35 12 V - SOCKET IN LOAD SPACE
U62 ILLUMINATION PACKAGE
U70 BRAKE CALIPERS PAINTED RED
V94 SPEED LOAD INDEX 91Y XL
VL FRONT AXLE HALF. LEFT
VR FRONT AXLE HALF. RIGHT
Y05 SEAT BELT IN RED
siR
Edinburgh
C63 & Golf GTI
Thanks, can anyone confirm this has the command audio system? Also is front locking diff rare on the a45?
Argus
Suffolk
W205 Brilliant Blue/Grey, M274
Perhaps one of you good people could post my data card please? I fetched it from DataMB.com but there seems to be a few irregularities.
Many thanks
WDD2120262B246713
gianton
Thessaloniki, Greece
S204 C250 CDI 4Matic Avantgarde - 2013
Many thanks
WDD2120262B246713
Datacard attached.
  • WDD2120262B246713.pdf
V6Matty
Newark, Nottinghamshire
can someone confirm where I can find the VIN from the reg number these days, I used to use MB extended warranty site but seems they have cottoned on to that and no longer show the vin after confirming your reg number.
Jimpey
Lancashire
ML 2011 350CDi, SL350 2003 3.7l
Wow!
Since I signed up to the forum last Wednesday I try to catch up on some of the past content each time I check in for new posts.
I just got to this thread (over 8 years, 160 pages and no sign of slowing down) and will say it again, Wow.
The members providing the data are either nuts (in a good way) or completely selfless - I need a smiley here that isn't in the selection provided......:)
I like to have 'original' paperwork for my stuff so make a point of finding manufacturers brochures, magazine reviews and the like (not just cars but hifi too) but the idea that pdf files of data cards might be available never occurred to me.
So, please could I trouble one of you wonderful decoders to run the vins for my-
SL WDB 230 4672F054019
ML WDC 164 1252A706528
Thanks v. much.
Jim
