Hi all - I have a silly problem: the spring in the luggage cover on my W124 estate has gone and it won't retract. Can anyone help? Should I just buy a replacement or can it be fixed?
I have just posted a thread on the same problem, but on my 1999 E 320 estate. Mine retracts partially. So can only sympathise but not help. Of you get an answer and which is not "replace" wld appreciate a call. 01179099036
UPDATE... the locating peg wasnt going up when the button was pressed, so i did get the whole thing out, all the bits fell out the plastic end cover when i took it off, but heres the problem now, the load cover is under tension, the cover came off and ZZZZZZZZZZZ the spring unloaded
i cant work out how to tension the spring to refit the plastic end cover...
Welwyn Merx Limited is a family run business with genuine passion, dedication and 25 years of experience dealing with Mercedes-Benz and AMG passenger cars. Tel: 01707 395999www.welwynmerx.uk
