Hi all - I have a silly problem: the spring in the luggage cover on my W124 estate has gone and it won't retract. Can anyone help? Should I just buy a replacement or can it be fixed?
I have just posted a thread on the same problem, but on my 1999 E 320 estate. Mine retracts partially. So can only sympathise but not help. Of you get an answer and which is not "replace" wld appreciate a call. 01179099036
UPDATE... the locating peg wasnt going up when the button was pressed, so i did get the whole thing out, all the bits fell out the plastic end cover when i took it off, but heres the problem now, the load cover is under tension, the cover came off and ZZZZZZZZZZZ the spring unloaded
i cant work out how to tension the spring to refit the plastic end cover...
WE HAVE NOW MOVED: 8 Hazel Road, Woolston, SO19 7GB Service, Repairs and remapping service Any queries, please do not hesitate to contactEmail@mbsofsouthampton.co.ukor alternatively you can phone Colin or Dave on 02380 445820, out of hours numbers are 07787913313 or 07907631681.
