W124 Water Drain unblocking
d215yq
Valencia, Spain
1987 W124 300D 280k miles
hey all,
The left front water drain pipe (the one that takes the water from the windscreen drain to the bottom of the car just behind the front left wheel) is blocked. It is blocked at the bottom and therefore can't be unblocked by coathanger/wire etc...and i can't see where the drain hole comes under the car (it dribbles out by a plastic trim piece bolted on) so can't unblock it from underneath.
Is it acceptable to use standard drain unblocking liquids i've used successfully on normal plug holes/showers, etc with good results or is there a better/more successful way to unblock it?
TIA, Ben
EmilysDad
Bury Lancs
ML350
how about net curtain wire? clicky It's usually flexible enough to do that type of job.
wireman
lancashire
It exits horizontally between the body and the plastics inner wing liner, above and behind the tyre.
Bang in the centre of the 1st pic, where the horizontal box meets the liner you can see a gap, it exits towards the middle of the car, 2nd pic from inner wing side.
Left hand side shown.
D
d215yq
Valencia, Spain
Thanks a lot guys...the soda crystals did not unblock it much so i'll study the car and pictures tomorrow and give it another go....then see if i need the net curtain wire.
D
d215yq
Valencia, Spain
BTW how did you get that inside photo...fiddly work but using quadruple wound bellwire as a "scoop" to get out all the dirt from where the drainhole goes into the wing finally worked and the drain is good as new.
Thanks again for the help!
wireman
lancashire
Small camera and thin arm.
I set my camera to macro and shoved it as far into the inner wing as I could, it surprised me that it worked.
Thanks for coming back and telling us how you got on.
Do check the other two scuttle drains for debris in their ends, one exits above the gearbox its end is a flattened affair to stop mucky air climbing back up it, massage it with water being poured into the heater intake, and while you are at it, there are two drains each side under the sills for the sun roof to check, one front one back, there are also three for the boot, one in the wheel well and one on each side compartment, all these seven have a round grommet with a tube poking out of it, up the tube is a diaphragm with 3 small holes that stops muck climbing up the tube, mud collects in the end and blocks them, mind you don't tear the rubber or peel the underseal from their periphery.
Not regularly clearing the drains might get you a rust hole in the boot floor or in the steel sun roof tray in the roof lining.
D
d215yq
Valencia, Spain
Thanks for the further info...are all those drains correct for the estate too...i've poured water everywhere and it seems the water off the rear roof is just channelled round the tailgate and out above the bumper, then there's one for the fuel cap filler, two for the sunroof and the two either side of the windscreen...all those work now but haven't checked the heater intake one....is that the grill just below the wiper? and then that should come out above the gearbox as you say?
wireman
lancashire
It is indeed, not very easy to see it but it hangs along the upper surface of the transmission tunnel, a pants leg affair with an exit either side about 3 inches in and at ten o'clock and two o'clock above and to the side of the tranny, with an outstretched arm and the bonnet up fully vertical you can reach it. Any collected leaf debris will compost in the bottom of the drain hose and glue the flattened exit up, it needs an occasional squeeze to make sure its not stuck.
Picture taken LHS looking backwards from top of starter motor, its that strange shaped thing in the middle you're after squeezing.
There are four drains on the sun roof one from each corner of the tray, on the saloon they exit near the jacking pads under the car, not sure about the tourer but the front ones will be the same.
sebastiaoenes
Lisbon, Portugal
W124 1986 200 TD Estate
Water in the drivers side!
Hello, I have a 200 TD W124 Estate and I noticed I have water on the floor in the drivers side both front and back, the eater seems to be more ate back then the front.
I have already clean the windscreen drains and I dont have sunroof, but the other drains I will try tomorrow but the water seems to come from the back of the car or the side pilar, do you have any idea what my problem could be? I'm getting serioslly woried about this because I'm afraid o end up with a pile of rust
Thank you
kth286
E320 Coupe 95
it is highly likely rusty rear windows lower surround (hidden by the glass rubber).
(luggage section)
brianbrian
cockney in the West Country
w124 250D, SL129-deisel
I had to have auto glass take the rear screen out of this 190d I just bought, water in boot and rear seats, cost £55.oo boot all nice and dry know. Hope this helps
speedyw124
W124/1991/230TE
230TE water Drain tubes.
Hi I'm a newbie to any forums, just bought a 230TE E Class Estate,
It was grubby so I gave it a wash and now the offside passengers foot well
is wet, are there any diagrams showing water outlet holes, Please before I drown my wife. :D whoops wrong face.:(
hope I've got this right ?
I can send you the document that shoes where all the drain points are on a 124
Hi Malcolm
Do you have the papers for the water drains for a 2003 SLK (R170)?
TimR
Not one issued for this,,, you just have the drains in front of the front screen and the heater box drain.
Tel: 020 8863 9233
