W211 Xenon Headlight RHD/LHD switch, Convenience Opening/Closing
janp
Cork, Ireland
W211 E270 CDI 2005
Hello,
I am new to the W211 so I wonder if someone can help me out with a couple of things.
1) RHD/LHD change on Xenon Headlights
I have read somewhere the EU w211 have the ability to change the headlight with some switch (mechanical or electrical idk) located somewhere on the headlight assembly itself. Is that correct and if yes does anybody have a picture of that switch ?
2) Convenience Open/Close feature
On my old S202 I had this feature with the IR based opening and closing of all windows by keeping the lock/unlock button depressed on the fob and pointing it at the IR receiver on the drivers door. The W211 has this same looking little 'window' on the door handle but so far I failed to make this work. Is that an optional extra and if yes would it be listed in a VIN decoder and which number would I be looking for. What I mean to ask is how do I find out if my W211 has a defect in the Convenience Open/Close feature or does it actually not have that feature fitted/enabled ?
I am driving a 2005 E 270 CDI Avantgarde
Kind Regards
Jan
Naraic
2005 CL500.
Hold the key very very close and very steady to the "window". Press open (or close) then press and hold again...should work.
J
janp
Cork, Ireland
W211 E270 CDI 2005
I have read about the possible 'user errors' before, also possible sunlight issues. I tried in the shade very steady at any range from 1m to right up the IR receiver. Also keep depressed and pressed two times. Unfortunately no luck. Before I start digging any deeper I just wonder how I can find out if my vehicle even has that feature or not.
Jan
Mr Filipov
Huntingdon
2017 BMW 535d Gran Turismo
The feature is present. On my W219 CLS it was very hit and miss. And when I say that I do mean it. Maybe once or twice it worked from distance in the soace of two years. Otger than that keep the key pointed at the sensor about a centimeter away and I would it to work mostly. Not really convenient if it has to be that close though lol
Craiglxviii
Cambs UK
Convenience open/ close has to be activated in the DIS before you can make it work using your keyfob.
J
janp
Cork, Ireland
W211 E270 CDI 2005
Thanks, how can I find out if its is activated ? It just not working could also be a defect. Also what does DIS stand for ?
Craiglxviii
Cambs UK
Press the steering wheel buttons until you find the Convenience menu, and take a look ;)
J
janp
Cork, Ireland
W211 E270 CDI 2005
Oh OK, that is indeed something I did not think of *lol*
Jan
My 2009 W211 can't change headlight to LHD , and my 2009 CLK can't either .
As the the global opening of Windows , maybe try new batteries ? There is nothing on either of my cars that needs setting up in convenience function , both cars just work , but only on the drivers side within 9 feet ish .
Craiglxviii
Cambs UK
Wighty, are you sure you don't have a small white lever very awkwardly placed on the rear of your headlamps? They don't convert to LHD (they do on the 212 facelift onwards) but the lever lifts a dazzle shield into place to cut off the dogleg beam extension for kerb/ verge illumination. Called "tourist mode" and it's been a feature on MBs from the late 90s...
Cheers Craig , but I spent over an hour a couple of years ago looking with mirrors , small hands (Beadle popped over to help :)) , read the drivers handbook etc , all with no result , but because it's you I'll go and look again .
Craiglxviii
Cambs UK
Heheh ;) do check in the manual, perhaps Tourist Mode was an option?
I've tried on my E320 to get my hands in , but without getting an injury I can't get the caps off the dipped headlight . Think I'll go with the 2 quid stick on douberry from eBay .
J
janp
Cork, Ireland
W211 E270 CDI 2005
  • #20
Hi again,
I have checked in the settings, under 'convenience' is only the setting for the folding mirrors, nothing about convenience opening/closing. I get the impression it was a standard feature on the W211 and nothing optional ? Just wondered cause a friend had a 'Classic' where this also did not work. The battery is definitely the next step, I try that before I look into taking the door handle apart. I have read that is not a small job.
Thanks for your help
Jan
PS: have not yet checked on the Xenons but I have read so far that its not a conversion but rather just 'cutting off' the top left part of the beam, in that case I have already the answer I needed. Was hoping I could use continental Headlight assemblies instead of special UK/IRL types and simply switch them.
