David Williams
- Jul 29, 2004
Hi Malcolm,
Do you have anything on W208? Went out Thursday night in very heavy rain & found a steady stream running in to the passenger foot well. I can't se where it would come from under the bonet.
Many thanks,
Miles.
Just done my 208 conv - I removed the grills OK but had to use a chisel to break two clips at the back of the engine but it all went back nice and tight. The hole for the heater is huge.... once I cleared everything out I noticed that the drain had a rubber plug on the back which drained into the nearside wing and it was this plug that had gummed up. If you put your hand in behind the aircon box you will see/feel the rubber bung, just pull it off the plastic spigot and you might find that that's all you need to do.
