£100 per panel??
radiovic
2002 C180 coupe
Rust bubbling up on a rear arch, and couple of other places
I'm thinking along the lines of 'nipping it in the bud' now before it gets worse
Called at a body shop today (1st time ever) -- Seemed to be a busy place so he must be OK if he's getting the biz!
He quoted £100 per panel --- in my case 3 panels = £300
How does that sound to those of you in the know?
Car is the more unusual Magma Rad 586
Vic
You must find out what he is going to do, if the metal,or what is left of the metal is left in place it will go again within 2 years. to get a bubble on the outside, water has come through on the inside as the metal is now porous.
If you are only keeping the car a short time then not too important, but for a lasting repair the rusting metal should be cut out and replaced
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
£100 a panel seems a bit to cheap IMO, I would be concerned about the quality of the rust removal/rust proofing process.
Tel: 020 8863 9233
