08 SL350 front pad replacement
OLLIECAT
FLINTSHIRE
SL350 08
Hi, need to replace front pads and was just checking on videos before i start job but video mentions putting vehicle on star to disable SBC, Am i just being over cautious and its a straight forward task which i have done many times before. Thanks
Do you have SBC on an 08 car buddy ?
You need to be very careful around SBC as it can operate unexpectedly and clamp fingers causing serious injury.
The correct way is to disable SBC via a suitable diagnostic tool.
O
OLLIECAT
FLINTSHIRE
SL350 08
Ok thanks both for replies , hopefully it doesn,t have SBC otherwise its a trip to someone with STAR to change a set of pads, annoying.
O
OLLIECAT
FLINTSHIRE
SL350 08
It,s an 08 facelift model and i,m fairly certain it has SBC fitted
When you turn the key to ignition position do you get a buzzing noise.
Buzzing = SBC
No buzzing and you're good to go.
flowrider
SL500 (R230)
can you just unplug SBC, no electric then no SBC?
You can but it may throw errors on reconnecting.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
SBC was phased out in 2006.
An 08 SL shouldn't have it.
Fast forward to 2m 30sec in the video to see an SBC pump in situ.
AMGeed
Poole, Dorset
^ Every day is a school day:D
O
OLLIECAT
FLINTSHIRE
SL350 08
Unfortunately they must have had a few left it,s got one fitted. Nothing ever easy is it, Thanks for replies
Get yourself an MB specific code reader.
Check it supports SBC disabling and you're good to go.
iCarsoft MB v2.0, MB-II both work.
Also Autel AP200 should work.
O
OLLIECAT
FLINTSHIRE
SL350 08
Well it wasn,t the pads after all just been informed by a reliable MB specialist its the pump.
O
OLLIECAT
FLINTSHIRE
SL350 08
  • #17
Turn ignition on and the sound of pump priming or going through some sort of sequence and when engine was running at initial start up same sort of noise, other than that nothing else, car drove and braked fine. then two weeks ago warning light saying brake service needed so assumed front pads, then today when taking to specialist for service and repair everything lit up red. Told pump gone , Looking into trying a reset so see what happens.
mioba
Nottingham and Köln
mercs are not prone to believe the fault is gone by deleting the error codes.
How many miles has it done? I'd guess at around 100k...
I'd guess the error was C249F.
AMGeed
Poole, Dorset
