1/2 impact gun ?
bembo449
gainsborough , lincolnshire
Currently have a snap 18v battery gun but its getting tired now and wont undo sone wheel nuts or crank bolts , so im looking at my options , replace with another bigger rated battery gun OR a comp air gun as i have a compressor ?? Any thoughts or opinions , what are you using ? Do you rate it ??
I have a Ryobi battery electric gun rated at 400Nm. Not overly expensive and works well.
Westheath
South London
Battery
Milwaukee 1/2 28v M2 x 6 batteries
Snap On 3/8 14v Compact x 2 batteries
Snap On 3/8 14v Ratchet x 2 batteries
Air Stuff
Blue point 3/8 1/2 3/4 air guns
Snap On Air chisel/hammer
Tried most of the rest out there over the years
but keep coming back to the above faithfuls.
Milwaukee have longevity problems with their 28v batteries
but its such a great tool with wrist breaking torque it stays.
bembo449
bembo449
Ok good stuff guys
On the comp air side
What compressor are you using to run your gun , is there a minimum sized comp id need to run a decent torque rated gun
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
Only other thing to keep in mind is the battery is mobile. Many times I have used mine to remove wheels far from the compressor.
EmilysDad
Bury Lancs
ML350
We have a few Milwaukee a work. They'e very impressive for relatively small gun ..... they're frequently asked to tighten a bucket full of M20 bolts
M80
Derbyshire
I've the same,
picked it up for £72,
2x 4Ahr batteries for £42,
charger for less than £20.
I've got a fair bit of Ryobi now so I bought extra batteries and a charger.
Even Larisa has her own Ryobi, the garden strimmer.
We have loads too. Couple of hedge trimmers, drills, saws, grinder. Very pleased with the kit so far.
Uncle Benz
West Sussex
Mainly Mercedes
I am a bit old school, and still use compressed air in my workshop. For years I favoured Chicago Pneumatic for my 1/2" impact guns, but for the last five I have used a MAC tools impact gun they call "the daddy". It has a titanium case, and the balance in the hand makes it much less tiring if you are using it all day, every day.
I recently came across a problem with a crank pulley bolt on a diesel BMW which defied even my 1" CP air impact gun. In the end I borrowed a 3/4" 18v Milwaukee gun, which just unscrewed the difficult bolt with absolutely no fuss at all. To say I was impressed is an understatement, and I bought one same day. I stand by my MAC gun as the first thing I reach for though. It is such a comfortable tool to use, I keep a brand new spare in its box just in case it ever lets me down!
bembo449
bembo449
thanks for all the info on this subject folks , experience counts when purchasing such kit , I reckon I may plump for the Milwaukee , it sounds like what the whole idea of these things were invented for , time save time !
would be great if I could lock the crank off and use my 1" drive set but there doesn't appear to be a way to do it
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
impressive figures pal , does it walk the walk ??
Overkill just for wheel bolts, but oh so easy! I have used it on wheel bolts, caliper carriers, lower arms amongst some others and it hasn't let me down. I should add this is DIY use but it definitely has some whack. I bought the batteries from eBay (£60 vs £100+ elsewhere)
bembo449
bembo449
it will be for DIY use although I do quite a lot and a few side jobs for beer money :)
Chrishazle
Nr Ashford, Kent
I have a Lidl/Parkside 10.8V 1/2" impact wrench that claims to put out up to 400Nm backing out but only 100Nm making up - so you can't overtorque your wheel nuts. It came in a carry case with charger, 5 impact sockets (wheel nut sizes) and a battery to 12v cigarette lighter lead for £40. First one did not hammer like it should, Lidl sent a replacement straight away. Not used it in anger yet, but for £40 it could be a good buy!
V6Matty
Newark, Nottinghamshire
Personally I’ve got dewalt too, comparison to Milwaukee in power term they are pretty much identical but it’s better balanced in the hand, I took a good hour trying different brands at ECAtoolfast and found the dewalt the most comfortable if holding for any period of time more then a couple of minutes.
Paired mind with a few 5ah batteries, normal charger not looked back in two years.
Frontstep
T210 320cdi
Well I don't use mine so often so I rely on an "arm" its ultra low voltage and runs on allsorts,
its always with me but like everything else its getting worn and reluctant to start.
If I could I would get some new ones.
bob 6600
Perfect. If you are ever near Coventry you are welcome to test it out
