107 SL interior heater stuck on.
simont5
Malmesbury, Wiltshire, England
Mercedes G wagen
The nearside heater on my 1987 107 SL is stuck on hot, though the slide moves up and down. Is this an easy fix, even if temporary as we all know what its like outside at the moment!!
Can I move something on a temporary basis behind the panel which I can get to when I move the underdash panel.
Any help would be appreciated.
Apologies if this is in the incorrect forum, but its the only one I can list a thread!
Many thanks
Simon
Ductman
Hampshire
C350 CDI Estate/R171 200 SLK/Lotus Exige V6/Lotus Evora GT410 Sport
Remove the under dash panel on the affected side and you will almost certainly find the flap lever arm has come loose on the spindle. A simple tightening of the securing screw in the correct position on the spindle should allow the flap to be moved by the slider.
A very common problem on 107s after several years.
If the controls are OK then it could be the duo valve stuck one side
Alex Crow
Super Suffolk
IIRC all the 107s have a single valve, that only closes when both heat control slides are at the 'cold' stop.
Is it the case that one lever will not travel fully to the 'cold' position?
Carl@MBS
<span style="color: red;">Authorised Forum Support
164 320 AMG & 211 320CDI
There is only one valve on these, the prob is normally the control lever mech behind the dash, if you take the glovebox out running behind the consol from left to right is a bar with a ten mm nut on it. This nut works slight loose and allows the arms to slip you will need to juggle the position of the two levers and tighten the nut back up job done.
Tel: 020 8863 9233
