I've checked the switch and replaced the relay which made them work for about a week.Now every time their turned on they blow a fuse.I'm right back where I started.Any ideas?Thanks everybody.
Check that the fuse makes good contact and not loose/damaged.
Under the bonnet, check wiring for damage/water/connections.
Investigate inside the motor, see post #17, yours will be much the same as in picture.
