After searching the planet I have managed to get a good used wiring loom! All installed and I now have a 6 cyl mercedes instead of 4 and a bit. However before I start pulling things apart I thought I would ask "the knowledge" here what to look for: Engine starts but struggles to maintain an idle. The first inch of accelerator pedal travel doesnt do anything and then hello 2000rpm. The engine seems to surge between 400 and 1000rpm or it just dies. The MAF looks brand new and is spotlessly clean. If I disconnect the MAF with the engine running the idle improves but only very, very slightly and the engine still dies. If I get throttle happy the rev limiter cuts in at 4000 (is this right?).
Any ideas on what to start with? I would like to be able to monitor the O2 sensor but where are the wires accessable or is there somewhere I can get multi meter plugged into it whilst its connected.
Any help appreciated and before someone says get over to your local stealer and have the codes read I need to get it running for the MOT which unfortunately expired.
Thanks all - Hurm
Thanks all - Hurm
