Hey folks, I am having a problem with a 1989 300e. It won;t idle when cold, and idles at around 1200-1400 rpm when warmed up. I cleaned the idle control valve, tried to make adjustments to the cis, but no luck. The Idle valve is recieving a signal, but will not make a difference to the engines condition if plugged or unplugged. I tried actuating the valve by using small jumper wires, and it clicks.
Now, I am wondering if it is possible the idle valve is not working, even though it clicks when powered, OR, if the signal to the idle valve is inapropriate. Any way to check the signal? What else can be causing this?
Thank in advance for helping a newbie!
Mike
Mike
