Has anyone had any experience of changing the seals in the tandem pumps fitted to some 124 estates? Are special tools needed? If there are, are there ways around?
If its the pump on the end of the cam .... then no problem .
Once you take the pump off its all self explanitory.
I didn't even disconnect the suppy hoses .
MB do a complete seal kit for about a tenner ;o)
I've never done one, but, looking at the parts drawings, it's quite a job - the flange doesn't come off the front end of the shaft, it's all one piece, which means you have to dimantle the pump to enable the shaft to be withdrawn, at which point you'll be able to fit the seal.
GAD was founded in 2009 where we developed bespoke ECU Remapping software for motorsport clients, moving forward, we have extended to road vehicles for both performance and economy, contact GAD Tuninghttp://www.GADTuning.co.ukto discuss your requirements.
