The sensor just stopped working.
Both bas/esp and the abs lights came on whilst driving. Went out once but came on once I had moved off, then have stayed on. No tracking, suspension work nor clipped a wheel, kerb or pothole.
My tip for this job is to replace the 10mm bolt that holds the steering wheel on, every time you remove it. Having been previously removed prior to my ownership, it began to round off as was a bit damaged.
I think it is torqued to 3000 lbs plus seven turns.
d:class automotive are specialists in automotive interiors and upholstery. From Mercedes and modern cars to custom and classics. Tel: 01483 722923
Email:info@dclass.co.ukWeb:www.dclass.co.uk
