129 sl 320 door/window seals ,need to source
Bult360
Preston
Sprinter
Hi , can anybody recommend a parts supplier who does the door/window seals for a 99 sl 320? Mine has started passing water around the front area of the drivers door glass around where a quarter light would be on an older vehicle , thankyou Pat
mikestrivens
Stockport
I've just replaced my w124 ones from Mercedes, around £30 each
chardF
Warwickshire
SL 1994 320 R129
Before you replace try Gummi Pfledge. It worked for mine.
It took a couple of goes over a couple of weeks.
(not all silicon lubes are the same :p)
You can also sometimes fix tired seals by threading a piece of tubing or foam inside the hollow section of seal.
I believe the seals are still available from MB.
