daveenty
- Jun 21, 2005
- Location
- The Frozen North :(
- 2019 AMG S Class Coupe
Would anyone happen to know for certain if the 12v socket in the boot is a permanent live with the ignition switched on, or does it power down after a while? This is on a C217
The reason for asking is that I've had a tracking device connected to it since I've had the car, nearly 3 years, and had nothing but trouble with it from the start. Practically every time I use it I'm getting phone calls/emails./messages warning me that the car is being driven without the ignition on. I've so far had two new units fitted, a firmware flash and numerous check over but it's still the same, hopefully up till today.
The latest engineer to call has suggested that the supply may be switching itself off after a certain amount of time, thereby triggering the warnings. This sounds logical to me, and coincides with the warnings only usually happening on longer journeys and not quick trips around the houses. He has now taken the feed from a different source which has been confirmed as being ignition switched and not auxiliary. He also intimated that when they now fit these devices to modern Mercedes, they are taking the live feed directly from the battery due to the complexity of the modern electronics and things powering down.
It would be of assistance if someone could actually confirm that the auxiliary socket does power off after a while of the boot being shut.
