12v battery
kevh9
C220 T-BACK 2012
Hi I have a c220 w205, every now and again I get a message saying " start engine see instruction manual". The car starts ok without any struggle and fires up every time. Last time it did this i bought a new battery, about 4 years ago. Mercedes Benz said both batteries are fine and it`s charging ok.Any ideas why this happens please.
daveenty
The Frozen North :(
2019 AMG S Class Coupe
Does the car get used regularly? They don't like being left unattended and will often sent the message you are seeing. You have a few levels to come with these messages by the way, mine is "Critical" quite often. :D
A lot of people leave their cars on trickle chargers if they're not being used often to maintain a constant charge level.
Srdl
New Forest, Hampshire
GLC43 AMG 2018 (X253)
Is this when you’re sitting in the car with the engine off? I have had it in the past when I have the radio or music on and the engine off. The Audio 20/Comand system uses quite a lot of juice.
K
kevh9
C220 T-BACK 2012
No not a lot of use. After thought mime says Critical as well. I will try trickle charging it.
Thanks for advice.
K
kevh9
C220 T-BACK 2012
Once or twice but mainly after its been stood a few days.
rich.g.williams
Cardiff, South Wales
C200 Kompressor Coupe 2003
Worth having a look at this recent thread:-
Parasitic Battery Drain
Its possible to discover what is drawing current from your battery, surprisingly even quite low levels of "parasitic drain" can flatten a big battery in days.
The problem is if the battery spends a lot of its life partially charged it will deteriorate faster. The magic number is 12.4 Volts - if a Lead Acid battery sits at less than 12.4 Volts for days it will be damaged.
