140 swb uneven tyre wear rear
Status
Not open for further replies.
a.140
New Registration
hi i have a 2001 a140 swb and the rear tyres more so the nearside rear have worn uneven on the in side edge,its done 31000 miles have been to mercedes and they said to get new tyres but does enyone know of a problem with the rear ,to couse this uneven wear......thanks
guydewdney
Tring, Herts
www.atct.co.uk
tracking? get a "geo check" done - proper 4 wheel laser alignment, not a simple tracking job - cost at least 50 quid and takes at least an hour.
do you mean that the tyre is worn uneven ACROSS the tread, ie the inside is worn and the outside isnt - or that at some points of the inside are worn and others arnt?
the former means tracking / alignment, the latter means knackered tyre / shocks / wheel bearing etc etc
guydewdney
Tring, Herts
www.atct.co.uk
mine was pulling to the left a bit too much, turned out the spring was broken - aparantly a common problem - 50 quid (80 dollars? each)
worth checking.
Spike
London
1999 SL500
Having seen your car, I must say that the rear end does sit rather low... as if its either been dropped or the springs are worn.
This would effect camber and unless adjusted, would produce the symptoms you describe.
I believe there are adjustable camber arms available.
Status
