18 tyre pressure?
Foe
Cardiff
2001 w210 e220 CDI auto
Hi having my car just under a month, I've not really thought about the tyre pressures, until now. I usually check the inflation once a month.
My w210 has non standard wheels, but instead has the 18" R230 SL Avior Alloy fitted.
Can someone please advise of the correct tyre pressure for both front and rear.
Try 33 alround buddy , unless the car is very heavily loaded . That's how I roll on both Mercs .
  • Like
Reactions: Foe
Foe
Foe
Cardiff
Excellent thanks. How much when fully loaded?
Good question , I would leave the fronts the same and up the rears to 36/37 , but that's just what I do .
  • Like
Reactions: Foe
If it all goes wrong it's probably written inside the petrol cap cover
Foe
Foe
Cardiff
A good point, thanks.Will follow your lead on this one. But the ones in the petrol cap aren't they for the original 16" alloys, or does it not matter?
I hate getting old, you seem to get confused and question everything!!
John Laidlaw
Wirral
Land Rover Discovery 4
Can’t go far wrong with Wighty’s pressures , that’s what I ran on 18s- barring that I think the Michelin site has recommended pressures
  • Like
Reactions: Foe
Foe
Foe
Cardiff
Thanks. I'll follow his lead.
L John
W204 C350 Petrol Elegance
Once a month, do you at least do a visual check each day before driving?
The lower the tyre profile the more important it is to maintain correct pressures, especially on the front.
Hit even a small pothole with under-inflated tyres and you could regret not checking more often.
  • Like
Reactions: Foe
Foe
Foe
Cardiff
Excellent advice, thanks.
Wheel size has little bearing on pressure. The vales in the filler cap will work pretty well for most sizes you can fit. As suggested by Wighty 33 is a decent start point.
  • Like
Reactions: Foe
