19" rims on C350??
Spice52
Wiltshire
C class
Hello
I have a 2012 C350 with 18" rims 35 profile tyres.
Its the AMG version so a bit lower
Can anyone confirm that I can fit 19" rims?
Thanks lots
Marcus
Frankly I wouldn't recommend it. The reduction in ride quality and increased susceptibility to rim damage will make an expensive uncomfortable mistake.
fabes
E400 Coupe
You can....
I looked at a 2011 E Coupe that had factory fitted 19" wheels
It did look good, but with 30 profile tyres on the rear, as wide as they were, the drop from 35 profile was noticeable on the test drive
I wouldn't recommend it, but yes you can and I was told by the MB dealer who had it that it was the same suspension as the car on 18's
JBell
Torquey
C350 CDi Estate (GAD Edition)
No problem at all
Wheels:
Front Wheels: 8Jx19 ET45
Rear Wheels: 9Jx19 ET54
Tyres:
Front: 225/35R19
Rear: 255/30R19
Spice52
Wiltshire
C class
Thank you all very much for the replies
Spice52
Wiltshire
C class
To add to that
What tyres would you recommend ?
I've got Conti's onbut the rear end can get pretty lively
Marcus
A.J.
Norwich. UK
To add to that
Marcus
Perhaps not Pirelli P Zero either, mines pretty lively too, plus I think they are quite noisy as well :rolleyes:
John Laidlaw
Wirral
Land Rover Discovery 4
19s aren’t too bad, 18s are smoother and optimum on our roads- as others avoid Conti, P Zero...add to that orrible Bridgestones and stick with the Rainsports JB mentions or GY as Dry run- I’d also recommend on mid range Vredesteins - underrated tyres IMO...
Rotorhead500
Very South Devon
Used to have a C63...
No problem at all
Wheels:
Tyres:
Front: 225/35R19
Rear: 255/30R19
235/35 on the front of mine JB.
OP- I run Uniroyal Rainsport 3 all round on mine and feel there is a noticeable improvement in rear grip over the previous Goodyears.
Either tyre will work, the 235 will give more grip being a bit wider
Thats a myth. A wider tyre just gives a different shaped contact patch and a more stable contact patch when cornering, but is more prone to aquaplaning in wet conditions and will have poorer grip in snow.
Tel: 020 8863 9233
