190 body resonance
Status
Not open for further replies.
jack-n-gill
Norfolk
Hi Guys
My 1989 190 2 litre has a strange body resonance. It only occurs in 5th.gear when power is applied at 60MPH up to about 70. equates to 2000 RPM up to 2300ish.
It doesn't do it in any of the other gears from a similar rev range.
Much more noticeable in the back. Makes a booming sound like driving over a newly laid concrete road surface- sort of!!
Any ideas what could be the problem?
andy_k
Bexhill On Sea, East Sussex
www.ak3dgfx.com
E55 AMG
I'd suggest rather than it being linked to the revs it's linked to the speed.
Check, rear wheel balance, wheel bearings, diff and tyres (is it possible one is slightly out of shape?) all of which could create noise from the rear.
Andy
jack-n-gill
Norfolk
Hi Andy
I suppose it could be but it don't happen at the same speed in any other gear. :(
I was wondering if it could be a bearing, but out of gear and coasting there's no sign of it. :?
Stumped me!!
flagstaff
York
'94 E220 Cab
i had this (or a similar-sounding) problem with a 190D one time. turned out that the prop shaft centre support bearing bush was badly worn. can't hurt to chck. if it's orn it's very obvious - there'll be a gap between bush and prop shaft, flaked rubber etc ... hope this helps
jack-n-gill
Norfolk
Cheers Flagstaff
I'll crawl under it at the weekend and have a wiggle. :?
Status
