190 Headlight removal - Is there a but I'm missing?
Status
Not open for further replies.
mpowell
Derbyshire
I am trying to remove my headlights to clean the inside of the glass as they are rather smoggy.  I have removed the top 2 nuts, the side lense and the strip at the bottom.  Is there a nut at the bottom I am missing as the damm thing wont budge.  I cant see anything and there is no where with easy access that i think there could b 1.  Is there some sort of clip, or am I missing something.
David Halsey
behind that strip is a screw, it is set about 30mm back from the strip
if you croutch down you will see it there
M
mpowell
Derbyshire
Behind the strip! The strip gap is about 15-20mm, how on earth are you supposed to ge to that.
David Halsey
use a 3/8" long extension with a 10mm socket on it. it will just fit.
willydog
you can reach the bottom clips from under the bumper but be careful
as they are very brittle and snap off very easily
Status
www.ckinsurance.co.uk
