190 heater problem can anyone help ?
Status
Not open for further replies.
bigbifter
s yorks
hi i've got a 1990 190e 2.0 petrol and the heater does not seem to get very warm, so far i have flushed the matrix and its clear and i have also replaced the thermostat, the car runs at normal operating temp 80-90 and stays there. is there any common problems with the 190 models. i have also got a loud creak when steering and over bumps i think its coming from the lower front ball joint is this another common problem ?.
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
My brother ended up replacing the matrix in his and worked fine for a couple of months, now back to cold air again. Checked dampers valves engine temp etc. It has to be something simple but till this day hasnt solved it. Bought a C class.
Sorry no help here, just curious.
Regards
Mike
190
Banned
Scotland
It may be a faulty control valve, it is located to the divers side of the heater motor make sure the valve is opening fully or even remove the pipes from the valve & join them together and give that a try. If you now have heat replace the valve.
Status
