Adrianh1
I have a 1993 190D 2.5 with 208k on the clock. 12,000 miles ago it was converted to run on veg oil using a twin-tank Smartveg system, a proprietory veg oil conversion brand (http://www.smartveg.com/how_does_smartveg_work/. The conversion has been a partial success with numerous niggles since it was installed 18 months ago. Most niggles have been ironed out. However the latest issue is proving stubborn to cure. I have uneven running (on veg AND diesel) and engine “missing”, with associated poor pulling performance, also random poor starting (lots of black smoke being kicked out).
To tackle the problem, the car has had a new lift pump, glow plugs, refurbed injectors, all new filters including veg fuel filters (the car was fitted with a Biotuning flat plate heat exchanger plus a Biotuning heated fuel filter). The veg fuel is good quality WVO from a North London gastro pub filtered thoroughly. I have used both my local garage and a diesel injection specialist (Phelps Transport in East London) to try and tackle the problem. My local garage doesn’t have enough knowledge/confidence to deal with veg fuel systems and Phelps hates working on vehicles that run on veg oil (definitely chin scratchers and blame the running woes all on using veg oil). I am planning to test for air leaks this weekend (weather permitting). I am wondering if any others (running on veg oil) have also experienced such problems? I understand O-rings in the fuel lines be worth looking at (I don’t’ know what O-rings are but I’m hoping to find out!). I’m also wondering if fuel pipes themselves may need clearing/replacement?
The car has been serviced meticulously during its life and, when running normally, runs beautifully smoothly and quietly. The pulling problems occur not just when the engine is under load but also when idling, especially when the engine has been working/pulling hard. Very unnerving.
Any thoughts/feedback much appreciated.
Adrian
Adrian
