flagstaff
hi
my autobox seems to be leaking ... smoke burning on exhaust after a run, quite a wide 'stain' down the underside of the car. took it to garage, who changed the g'box sump gasket and put some kind of sealant around where the filler pipe goes into the 'box. but ... still leaking!! are there other well-known areas/points for this 'box to leak from? gears change fine and smooth, actual fluid loss is not that much but it's still worrying. any tips/ideas would be most welcome, thanks.
