190E front brakes - Wear on pads
Status
Not open for further replies.
Armitstead
New Registration
Lancashire
The outside disc pad on the off side front wears out very quickley
There does not seem to be any sticking in the caliper mechanism. any ideas
Andy
West Midlands
www.mercedesservicing.com
190E front brakes
Hi
I think your problem is to do with the actual pin which support the floating caliper. The side which the pads wear down on you will probably find that the brakes are binding slightly. Replace the two pins, wear the 13mm bolts screw into. I doubt if the dealers will have them in stock, but they are available along with a gaitor kit. They are only £6or 7 pounds each. If you like to contact me visit www.mercedesservicing.com
This should resolve the problem.
Status
