Has anyone had problems with erratic engine running and replaced the OVP and cured it. The reason I ask is that the OVP relay comes up quite a few times in this forum as being the culprit, but not many people reply to say thay have solved the problem with fitting one.
My tickover when running erratic is 1100 rpm at standstill. on the move it goes up and down between 1250 and 1500 rpm surging but only when I do not touch the gas pedal.
If I sometimes stop and restart the engine it can go away, and the car runs perfect. It has been surgested that it is my OVP Relay in these forums, but because it does not do it all the time I feel as though I am throwing money at it undully. If it is the OVP for certain I have not got a problem buying a new one, it is the suck it and see I am trying to avoid.
Would the switch on the the end of the throttle cable give the same symptoms as described above if it was faulty?
Or would the Idle valve be intermitantly faulty?
