drainaudio
Hi all.
I have 2 very slight water leaks into the boot and have located the source of the problem as the bottom corners of the rear window rubber - looks as though the original factory sealant bead has just perished a bit over time in an area about 3 or 4 inches long. Should I just try and get some silicone sealant in there, which to be honest isn't going to be easy due to the very tight spaces in this area or should I just bite the bullet and pay the £50 it will cost for a windscreeen guy to do a proper re-seal of the rear winow rubber?
Thanks, Geoff.
Thanks, Geoff.
