Hi,I have been having a annoying problem with my old 190e,its a 1987 2ltr manual done about 175,000 miles,I have owned this car\for 12 years now,and over the years have replaced all the usual parts,
the thing is it takes a bit of turning over only when cold,to start it,then ticks over at 900,it used to tick over at 1100 till it got warm,then drop back to 900 ish.I started by changing the cold start valve.[I have a 1992 190 which I am using for spares,starts first time ] the auxiliary start valve I changed next,then the ecu,the throttle micro switch,checked all vacumm pipes.
I would like to change the idle speed air distributor but the doner car has a circular type dont know if its possible to change the whole thing,also the same with the temp sender ,three wires as apposed to two?
I do intend to change the injection asembly when I have time,it lookes a lot cleaner inside than mine,
its the Bosh jetronic and fuel is getting to all parts under pressure,am I being to fussy over the starting,.I am beginning to think it might be electrical or sensor problem,should there be voltage at the cold start valve with just the ignition on when cold?any ideas much appreciated thanks
