Hi, I recently bought a 1987 190e (2.0 auto) and I was very happy with the car (my first Mercedes) until two days ago when I took it to a local garage to have the exhaust emissions checked (the car needed slight throttle to start 'cleanly' when hot, OK when cold). The technician found he was unable to adjust the mixture and the engine was running lean.
He suggested I bring the car in to have the injection/induction system cleaned out before attempting to adjust the mixture again. He cleaned everything, and upon reassembly the car refused to start. (I beleive it started momentarily then faltered)
It has since been disassembled and they have established that fuel is reaching the fuel distributer or fuel pressure regulator but is not reaching the cylinders! Apparently the injectors are clean. The car was running beautifully when I dropped it off at the garage.
Any ideas?
Also, does anyone know how much a secondhand fuel pressure regulator and fuel distributor cost?
Thank you for any info and thanks for such an impressive web site.
Any ideas?
