1987 210 campervan - Heater
Spen185
210 camper petrol
Hello all, could really use some help.
Last year I bought a 1987 210 camper and have been relentlessly working on it.
Got it driving nicely but now realising the heater doesn’t work and on closer inspection have found the valve is stuck, the cable is rusty, the heater fan is fairly seized and the control panel in the cab is broken. Not a lot then! I need to get all 4 parts, would rather new but I will take what I can get. Can anyone please point me in the right direction?
clarkmichigan55b
sunny Surrey on a sunny day
Mercedes 208D T1 van 1989
Hello,
Try Your local Mercedes commercial vehicle dealer. Take you chassis number with you. Quite a lot of parts are still available and the heater motor is a common problem.
Unless you have already done so the dash board has to come out with the gauges. You need a puller on the steering wheel as it has a parallel shaft.
Check the condition of the heater matrix and hoses when apart.
Hope this is of help.
