I have a problem with the lights that illuminate the instrument panel, heater switch's, gear selection panel etc. The lights should illuminate when the light selector switch is turned on. Just went . Any help would be appreciated.
Have you adjusted the dimmer?
A lot of people don't know its there. If you're one of them, twist the mileometer reset switch.
The rheostat is also known to fail so if that doesn't work, this may be the problem.
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
