Mad Professor
- Oct 18, 2008
- Location
- Isle Of Wight
- 230TE/1988/2.3
Good Day All.
In the last few days I have brought a 1988 230TE Estate.
When the car is 1st started or cold you can not touch the throttle or the engine will splutter or die, if it starts without needing the throttle you have to let the engine idle for up to 5mins before you can use the throttle.
The car is just sat on my driveway at this point in time wile I am waiting for all the paper work needed to get it on the road, so now is the best time to try and get any problems sorted.
I don't know when the car was last serviced so I am going to change the fuel filter, oil filter, oil, plug, rotor arm, and dizzy cap, and air filter, so that I know they are all good.
Due to its age I am also going to put some fuel cleaner in the tank, what would you say I should use? Redex, ect?
I have not looked into the problem yet, over the last few days I have just been making a To-Do list.
What do you think the problem might be, and what should I look at?
Thanks for your time.
