Now and again I loose the electrical feed to the fuel pump, engine cranks will not start.
1- Have run a direct feed from the battery via a switch to the pump, this will start the car and will run fine.
2-Turn the switch off and most of the time the car will start and run ok.
3-Is the fuel pump relay at fault and where is it?? the relays by the fuse box are not named.
4-Is there a fuel cut out??
5-Fuel solenoid valve in the system, haynes not very clear.
Need some help ASAP, HAVE A 1000 MILE ROUND TRIP SOON!!
Thanks.................124coupe
