costin_popirlan
- Jun 16, 2007
Hello
I've been having problems with the idling speed - around normal when cold and 1500 rpm when hot + high fuel consumption. - so... i researched the problem in my haynes manual and checked all the electric components and, according to the numbers in the manual, they seem fine.
I had the injection system cleaned (dirty fuel) and changed the injectors and their rubber guides. Still the same idling problem.
I started to 'play' with the mixture adjustments with not much success:
- idle ok when cold - high when hot;
- idle ok when hot - wont idle when cold;
I changed the hose between the idlespeed valve and 'under the fuel distributor' as it wasn't airtight.
I am out of ideeas....
I think that the idlespeed controll valve is not working properly or is not controlled properly. When i feed it 12v it engages.
Any ideas on how to test it while the engine is running...? What readings should i get...?
Please help...
Anybody...
Please help...
Anybody...
