Garista
- Apr 29, 2018
- Location
- France
- 2001 ML 270 CDI. 1991 R129 300 SL
- Thread Starter
- Thread starter
- #81
Figured this out from the web:
ASR II system checks:
The most common cause of power loss in these systems is a blown fuse. If you have checked all the fuses and they are all good, then you need to look for a loose one or a bad connection or break in the wiring. Another possible cause of power loss is a faulty relay.
The throttle control components of the ASR II system = the throttle potentiometer (R25), the throttle drive motor (M16) that communicates with the Electronic Accelerator/Cruise Control/Idle Speed Control (EA/CC/ISC) and the ABS/ASR control module, it also has the wheel speed sensors.
R25 proper 7.2V reference voltage. Specs: 6.5V at closed throttle, decreasing to 0.70V when at WOT position.
The safety switch in the actuator changes at 5.9V.
Safety switch in the pedal position sensor correct control voltage at about 6.2V.
Test the power feed at the ABS control module from the over-voltage protection relay (OVPR). You need to see less than 0.3v drop from battery voltage on pin 1 of the ABS/ASR control module.
This is what I am up to at the moment! When it stops thundering and hailing.
