1991 500 sl alternator squeal.
pancholi
1996 SL 500 , 2003 CL55K, 2004 E320CDI
last winter (feb 2006) when the car was started first thing in the morning a high pitched squeal would eminate from the engine bay.this was traked down by april to a worn alternator, by which time it had stopped as i did not need the headlights/heater/heated seats...... i exchanged the unit 2 months ago and as winter has now closed in it has made no difference. ie the squealing is still there until the car warms up (up to 10 minutes). i am driving around without the heater and turn of the lights at the first opportunity. any guidence please
Normally the sqeeking is the belt slipping when started, I have only ever known this to be the case. If it also does it on full lock then it is the belt too lose
Malcolm
stats007
Hampshire
Looking
Loose or worn - either the pulley or belt. They're fairly accessible so should be easy enough to check.
You don't want a new alternator - they're around £500 new.
pancholi
pancholi
to late!!!!! put one in 2 months ago!!!!
after being told by 2 garage owners it was ok.
its going in to a merc dealership for 4x wheel alignment i will ask them to check it then.
thanks
stats007
Hampshire
Looking
You dont want to put it into a dealers for 4-wheel alignment - they'll sting you for the best part of £300!
