1991 500sl engine problem
sajy786
my engine has siezed, oil and water is thier the car did not brake down i parked it up and it did not start, the engine is locked:confused:
Daeths
North Kent
T212 facelift, 2013. A few toys including pan roof, 19" rims, Harmon Kardon, nappa, privacy glass.
You say the engine is locked is that what you mean, or is it not turning over which could be a raft of different issues
adam
sajy786
got the rac out he tried to turn the engine over after takin the starter out, it did not turn
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Which SL R107 R129, timing chain snapped and jammed engine!!!!!! take the plugs out and try to rotate it with a socket on the bottom pully.
jib
sajy786
jib[/QUOTE]
if it rotates would it be the chain
Try turning anti clockwise if it is the chain, then it will turn anticlockwise for a little way
sajy786
how much damage is it likely to do?
something must have gone wrong when i turned the car off before that it was running fine and smooth
I do not think that the diagnosis is correct, still think it is battery or starter at fault, these engines do not stop this way
sajy786
someone told me its a guide rail near the timing chain that might have fell into the gear and locked it up
need more advice pleaz
Have you tried to turn it backwards with a spanner on the crankshaft pulley
sajy786
locked both way, after removing the starter
Tel: 020 8863 9233
