i have looked at other threads but did not know if it applied to the 500sl, do i need a 'puller' to remove the instrument cluster to replace a warning bulb?
thanks
There is a tool to pull these out, however, most people don't use it due to it being very easy to break to cover of the cluster -expensive!! As above, remove the carpeted undertray & push it out.
