1991 Mercedes 190E
euginie
New Registration
Are the rear subframe bushes on my 1991 Mercedes 190E straight forward to change, apparently they're worn.
Any simple tips on how to replace them.
Euginie
frank133
subframe
Hi my sub frame bushes were shot for quite a long time,I was going to replace them,but a whole sub frame plus diff became available,so I just changed the lot,I dont think its a job to do with the sub frame on the car.It is fairly easy to remove the whole sub frame with a couple of good trolley jacks.I would have cut the old bushes out and then made somthing to press the new ones in.As I said it is better to sort out with the sub frame removed off the car.
It took me about four hours to change the sub frame and to be honest I found it pretty hard work.best of luck if you do it yourself
